ldm_as
7 years agoCan SignalTap work without clock?
Hi All, Can SignalTap work without clock? I actually only want to see the logic values of the signals, which are not timed by clock (async resets, etc) Thank you!
- 7 years ago
If you want to see internal signal levels during runtime without a clock, use In-System Sources & Probes instead of Signal Tap.
#iwork4intel
sstrell
7 years agoIf you want to see internal signal levels during runtime without a clock, use In-System Sources & Probes instead of Signal Tap.
#iwork4intel
