GSzak1
7 years agoCan Quartus Prime 16 detect changes in sources to show the build is out of date?
I'm working with a project in Quartus Prime 16.0 that inherited from a previous designer. When I edit source files or update IP, Quartus doesn't seem to recognize the changes. If I double-click "Co...
Vicky1
7 years agoHi Gabor,
It is recommended that, whenever you want to use project which is created in different edition & version need to clear database associated with previous edition & version using 'Project'->'Clean Project' Menu option & then if project consists of multiple IPs or Qsys components need to regenerate before recompiling process. In this case if few IP requires license, you need to purchase license for that particular IP. You can verify with Quartus Lite 18.1.
Vicky
