GSzak1
7 years agoCan Quartus Prime 16 detect changes in sources to show the build is out of date?
I'm working with a project in Quartus Prime 16.0 that inherited from a previous designer. When I edit source files or update IP, Quartus doesn't seem to recognize the changes. If I double-click "Co...
Vicky1
7 years agoHi,
May I know, which Quartus edition(Lite/Pro/Std) are you using?
why don`t do you use latest Quartus version(Lite edition is free) where most of the issues have been already fixed?
You can check different available settings under 'Assignments' -> ''settings Menu.
Vicky
