can oneapi run on all FPGA boards?
I currently have a de1-soc but I was unsure if i can use the oneapi base toolkit + Quartus prime + bsp on it to deploy custom logic?
Also do you think it would be possible for me to deploy the hough transform on my de1-soc by using the fpga-selector ? I
I just completed the steps for emulation,optimization and bit stream generation on jupyterlab to get familiar with the development/deployment flow and my next step was to integrate oneapi with a board. What do you suggest I do as my next step?
I have also completed some projects previously using quartus prime, qsys and my de1-soc board. My goal was to try and run these same projects on the same de1-soc or an approved board(as given on the website) but with oneapi this time and code the same script in CPP or DPCPP.
Thank you.
- hareesh
to use oneAPI C code there is an IP Authoring flow.. which involves compiling oneAPI C code and includes it as part of the component in the platform designer
This is the example design for your requirement, but the problem is it's for the arria10 soc board not for de1.
Unfortunately, it is decided from the strategic level based on the oneAPI roadmap
and cyclone are not part of the support roadmap for now
- hareesh
- hareesh
