can not open VCD file
I am new to Quartus II. I have created a very simple program for shift register in VHDL. It was successfully compiled. Then I used the University program VWF to create the input waveforms and saved it. When I run it, the last statement is "can not open .......filename .vcd file". However I went to the simulation subdirectory and I can open the file myself inside Quartus II environment. I have tried other files that I previously did. They are working fine. This one is not. Can someone help?
Also, is there a location in Altera where all the error listings are compiled? can someone send me that link? I could not figure it out. Thanks for your help. Using Quartus Prime Lite 15.0, FPGA: MAX10 I am getting this problem on another unrelated program (attached). It compiles without any error. When I simulate with a .vwf file, the program runs fine, except at the end it states: Unable to open C:/altera_lite/Workbench/cnt8b/simulation/qsim/cnt8b.msim.vcd Error. I notice that the file exists in the directory. In the properties, there is nothing suspicious.8 Replies
Hi:
I am new to Quartus II. I have met the same problem as you. It was successfully compiled. Then I used the University program VWF to create the input waveforms and saved it. When I run it, the last statement is "can not open .......filename .vcd file". Hence, I would like to turn to you. Thanks for your help. Using Quartus 13.1,FPGA - Altera_Forum
what is the version of model sim you using now?
Quartus II 13.1.0.162 and ModelSim-Altera 10.1d (Quartus II 13.1),Would you like to tell me the detail reasons for this. Thank you very much!
--- Quote Start --- Quartus II 13.1.0.162 and ModelSim-Altera 10.1d (Quartus II 13.1),Would you like to tell me the detail reasons for this. Thank you very much! --- Quote End --- I am using Quartus Prime 15.1.0 Lite edition, and Modelsim PE student edition, 10.4a revision 2015.03. I am interested to know the root cause and the means to open the VCD file. Thanks for your help. - Altera_Forum
I amy have replied earilier. in case I missed it, here it is again.
I have solved the problem in the link. - Altera_Forum
Sorry for the delayed response. I was tied up on another project. The Modelsim version is PE Student Edition 10.4a.
Thank you. I am tied up on another project. I will try it as soon as I can make some time.
