9 years agoCan not load .sof file to the actual FPGA chip
Hello, Please be aware Im new to FPGA programming. I have tried the following code. http://www.alteraforum.com/forum/attachment.php?attachmentid=13091&stc=1 Im using...
9 years agoHello,
From the terrasic web site you can download a resources cd for your board. In this resources set there is a tool included called system builder. This tool generates a basic project with all pin and other settings that you can open with quartus. You can try to generate, compile and download the small project to start your diagnosis from. There is also a DE115 manual from the same source, see chapter 5 for detailed information about the system builder. Best Regards, Johi.
