9 years agoCan not load .sof file to the actual FPGA chip
Hello, Please be aware Im new to FPGA programming. I have tried the following code. http://www.alteraforum.com/forum/attachment.php?attachmentid=13091&stc=1 Im using...
9 years agoThanks @yahdskjas. It is solved now. The problem was with a JTAG server. It said jtag server error code 89. I just had to create a config file (/etc/udev/rules.d/98-altera.rules), put the followin config and restart the server.
I don't understand what this all means but it works now ;) # USB-Blaster SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster/%k" SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6002", MODE="0666", SYMLINK+="usbblaster/%k" SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6003", MODE="0666", SYMLINK+="usbblaster/%k" # USB-Blaster II SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6010", MODE="0666", SYMLINK+="usbblaster2/%k" SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6810", MODE="0666", SYMLINK+="usbblaster2/%k"
