MSheh4
3 years agoCan not generate the .jic file in lite version of 22.1 for cyclone V
Hi Dear,
I am having an issue with the lite 22.1 version, while generating the jic file using Convert Programming File tool. I got the following error
Error (23065): Remote update mod...
Rick1
3 years agoDid you manage to find a solution to this problem? If so, can you share it?
I am getting the same error for a Cyclone V project that I am updating from 18.1 to 22.1. From the knowledge base link you shared it looks that there is some hardware issue with Cyclone/Arria 10 that they work around with an extra check. But somehow this check also triggers when targeting Cyclone V.
If I try to change the address to 0x20 as suggested I get this: Page start address 20 is not a valid block address for the MT25QL512 flash device
