The only LVDS limitation mentioned in the SignalTap chapter of the Quartus handbook:
--- Quote Start --- Untappable Signals Not all of the post-fitting signals in your design are available in the SignalTap II: post-fitting filter in the Node Finder dialog box. The following signal types cannot be tapped: ■ ... ■ LVDS—You cannot tap the data output from a serializer/deserializer (SERDES) block. --- Quote End --- - Altera_Forum
Thanks Brad!
It is really bad news for me though. :( Wonder if there are other ways to probe a serializer output other than using an oscilloscope... - Altera_Forum
try post-fit simulation and DSO
