10 years agoCan I use Signal Tap for Altera OpenCL analysis?
Hello everyone, I'm trying to use signal tap for OpenCL analysis. But I couldn't compile the design with Signal Tap resources by quartus II or AOCL. Do you have any option to use Sign...
10 years ago --- Quote Start --- This signal tap should be only with FGPA area for signal processing, however the open CL is mainly for C/C++ software algorithm data processing. And mainly more to the kernel +host software. so far not yet heard of signal tap in open CL yet. why do you need that usage? --- Quote End --- I only wanted to analyze the kernel's data behavior by Signal Tap. Thank you.
