12 years ago
can i declare a 2D array as following ?
hi every body
type dataout is array (6 downto 0,11 downto 0) of std_logic_vector(7 downto 0);
i guess this is a 3D array not 2D.
so how i can have a 2d array of std_logic_vector?
thank u
    For a 2D array just have one range in the brackets, instead of two.
    type dataout is array (6 downto 0) of std_logic_vector(7 downto 0);
    This will result in an array of 7 std_logic_vectors of range 7 downto 0.
    --- Quote Start ---
    --- Quote End ---
    Nope, thats not a 2d array, thats a 1d array of 1d array. So you access it like this:
    output <= dout(x).
    A 2d array is declared like the OP posted. He made a 2d array of 1d arrays. You would access it like this:
    output <= dout(x,y); --and then add 2nd set of brackets to get individual bits
    thanks a lot my friend!
    --- Quote Start ---
    output <= dout(x).
    --- Quote End ---
    i wanna initialize this vector, i have a 2d matrix of std_logic_vector
    can i write like this:
    constant d : dataout :=(
                    -- Content           -- Address(i,j)
                    "00111100",        -- 0,0               "11110000"    --0,1               "01100010"   --0,2                 "01100010"   --0,3           ...
                    "01100010",        -- 1,0               "10011000",   --1,1              "10111000"   --1,2               "00111000"    --1,3           ...
                    "00111100",        -- 2,0               "11110000"   --2,1                "01100010"  --2,2                 "01100010"   --2,3            ...
