15 years ago --- Quote Start --- You need to write some addtional logic, mainly an address counter, and use a RAM instance with one port enabled for the in system memory editor tool. It's easily done with the MegaWizard. Or use SignalTap and export the data to a file. --- Quote End --- Hi Fvm, do you mean i should check "Allow In System Memory content Editor to capture and update content..." when creating the LPM_RAM?
