11 years ago
can cyclone V pll be feeded with global I/O pin clock
Hi
Sadly i got clock routed to non dedicated pin. I want to use pll in cyclone V device to get desired frequencies from it. Then i connect clock to pll i got the following error:
The PLL reference clock input pin<pinname>was not placed in a dedicated input pin that can reach fractional PLL <PLL name>
I added altctrlbuf but the error stays. Is it then possible to feed pll from non dedicated clock pin ? I read the documentation and I found that there is only requirement for global clock line.
1 Reply
    Sorry to be the bearer of bad news, but you can only feed PLLs from the dedicated clock inputs.
    If you can add a loop to your board, from a spare I/O pin to a (hopefully free) dedicated clock input, you should be able to get something working. Route the clock you want out of the spare I/O pin so that, via your new loop, it feeds the dedicated clock pin. Note: this will add a little jitter but, assuming your mod is tidy, not enough to stop the PLL working.
    Cheers,
    Alex
