11 years agocan cyclone V pll be feeded with global I/O pin clock
Hi Sadly i got clock routed to non dedicated pin. I want to use pll in cyclone V device to get desired frequencies from it. Then i connect clock to pll i got the following error: The PLL refe...
11 years agoSorry to be the bearer of bad news, but you can only feed PLLs from the dedicated clock inputs.
If you can add a loop to your board, from a spare I/O pin to a (hopefully free) dedicated clock input, you should be able to get something working. Route the clock you want out of the spare I/O pin so that, via your new loop, it feeds the dedicated clock pin. Note: this will add a little jitter but, assuming your mod is tidy, not enough to stop the PLL working. Cheers, Alex
