gyuunyuu
Contributor
5 years agoCan Avalon-MM Slave BFM Intel FPGA IP be used to implement a memory block?
In a memory block, reading the same address, shall give the same data value. Can this be implemented using the Avalon-MM Slave BFM Intel FPGA IP for verification purpose?
EricMunYew_C_Intel
5 years agoThe Avalon-MM Slave BFM is a bridge and cannot be used to implement memory block.
