gyuunyuu
Contributor
5 years agoCan Avalon-MM Slave BFM Intel FPGA IP be used to implement a memory block?
In a memory block, reading the same address, shall give the same data value. Can this be implemented using the Avalon-MM Slave BFM Intel FPGA IP for verification purpose?
gyuunyuu
Contributor
5 years agoThere is also this function called set_response_timeout which has been left inside the altera_avalon_mm_slave_bfm.sv but does absolutely nothing. Why is this so?
