9 years agoCan actual delays be implemented with .sdc constrains?
Hi, Can actual delays be implemented with .sdc constrains? I will try to explain what i want to achieve: Lets say i have PLL with two output clocks "pll_c0" and "pll_c1". "pll_c0" d...
9 years agoyour interpretation of valid window is correct in both cases
The tool does not care about comparing these values. It just wants to pass timing and it sees wide transition window available In short sdc is not meant for fine tuning of delays. I don't see why you need that
