9 years agoCan actual delays be implemented with .sdc constrains?
Hi, Can actual delays be implemented with .sdc constrains? I will try to explain what i want to achieve: Lets say i have PLL with two output clocks "pll_c0" and "pll_c1". "pll_c0" d...
9 years ago --- Quote Start --- What device? --- Quote End --- Cyclone IV, or MAX 10. --- Quote Start --- The PLL won't phase-shift an output due to constraints, that has to be done manually --- Quote End --- Yes, ofcourse I understand that and I use for this purpose dynamic phase shift option. :) Can you explain how set_output_delay command in .sdc file relates to Delay Chain values? I have tried to set Delay chain values manualy but for now i can not understand how to set my .sdc file?
