Byteblaster Error"Kernel mode driver not installed"
Hi ,I am facing problem. I use a PCIe Parallel port card, Installed it's driver and also the byteblaster's but when i program the PFGA it shows that "kernel mode driver not installed".I've changed the regedit follow as those suggests,--"Now my Byteblaster2 is running with my PCI parallel port adapter. The problem was during QuartusII installation the field "DependIOnService" of AlteraByteBlaster (HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\ AlteraByteBlaster) in Windows registry was filled in to be dependent from service "parport". When I installed my PCI parallel port adapter (MosChip chipset) the service installed to take care of parallel port was NmPar. Since I pointed "DependIOnService" of AlteraByteBlaster to "NmPar I dont have problem using Byteblaster2 anymore."
but it still does not work now. My PCIe Parallel port card's type is MM-PCEMSC9901-2S1P which powered by MOSCHIP . it phsical I/O adrress is D000-D007. I do not understand why Quartus2 can't find the LPT1 port,and how can i save problem,please?
