11 years ago
button with fpga pull up, gnd
I connected push button to gpio_1 pins on Altera DE2 board.
In verilog code I assigned one button pin 'r' as ouput to gnd, another pin 'c' inout tri1 (pull up).
I want to make inverter for 'c' to drive any of DE2 onboard LEDS, when button pressed LED would lit.
module link_klavos2 (q, c, r );
output q;
inout tri1 c;
output r;
supply0 gnd;
assign r = gnd;
assign q = ~c;
endmodule
In Aldec-HDL environment I got compiled, but in Quartus it wont synthesize, error:
Error (10664): Bidirectional port "GPIO_1[35]" at main3.v(35) directly or indirectly feeds itself
    You need to post more (all) of your code - what you've posted has mistakes in but the error relates to something you haven't posted. Post the whole of main3.v, preferably wrapped in QUOTE tags...
    Cheers,
    Alex
    Thanks for reply. My task is to connect a button to fpga port, configure one pin as GND, other as pull up, and drive a LED depending on button state. I attached picture illustrating it.
    Problems is that I don't know how to correctly assign pull up.
    I tried using tri1 with directions:
    output - measured 3.333V. LED all time off.
    input - measured 3V. When button not pressed - LED off, when pressed On.
    inout - measured ~200mV. When button not pressed - LED off, when pressed On. It works, but even if I touch the pins metal with finger, the LED turns on.
    At last I got It woking as input.
    Iam using Aldec- HDL, in block diagram I changed pin direction in module and terminal direction equally.
    output wire q;
    inout tri1 c;
    output reg r;
    initial begin r = 0; end
    assign q = ~c;
    endmodule
    I recommend not trying and implement the internal pull-up in your source code. I don't think Quartus does anything with it.
    Assuming you're using a DE2 board with a Cyclone IV device - in Quartus, in the Pin Planner, in the row with your 'c' signal in you need to turn the internal pull-up 'on'. Do this in the 'Weak Pull-Up Resistor' column. If you can't see this column by default right click anywhere in the column headings and select it to make it visible.
    If it's a DE2 board with a Cyclone II device you can't do this.
    Cheers,
    Alex
