--- Quote Start ---
I'm working on a project that I almost had done about four months ago, but then I had an accident that kept me from working. I'm getting back on top of it now but I'm having trouble with merging nodes into a common buss and pulling a line off a bus into a single node. I don't remember having this problem before the accident but now everything I do doesn't work the way I remembered. At first I thought I just wasn't reading the help and tutorial info right, but then I tried some files that I had done before the accident and they all worked like I thought they should. So now I'm not sure what's wrong.
I've tried to isolate the problem as much as I can. I hope my description is clear enough. If anyone is interested I can email the files. Here is the info on a mock design that demonstrates the problem(at least one of them anyway):
I'm developing using BDF files in the Block Diagram/ Schematic editor.
I have a Top-Level file which calls a sub file which has only 3 pins a Data Input Pin, a Clock Pin and a 4 bit wide Data Output Buss. The sub file is just 4 D Flip Flops wired as a serial input parallel output. The output bus Pin is named D[3..0], it is fed by a Bus Line(this is the problem line). The output of each Flip Flop feeds a node line which are labeled D3, D2, D1, D0 respectively.
If I name the bus feeding the output bus pin D[3..0] I get this warning:
Warning: Pin "D[3..0]" is missing source
Warning: Pin "BCLK" not connected
Warning: Pin SIN not connected
A problem with all of my I/Os
Double clicking on the first error highlights the problem bus line, named D[3..0]
If I then rename the same bus D3,D2,D1,D0
Everything compiles fine and the simulations are exactly what I would expect.
The output bus pin is named D[3..0] in either case the only change is renaming that one bus feeding the output pin.
Just as an added piece of information, I can modify the older files and they work as I would expect regardless of the naming conventions used or how they are modified. All the new files I've created have this problem.
Any thoughts would be greatly appreciated.
Steve
--- Quote End ---
can post your project or schemtic in the forum ?
Kind regards
GPK
