Altera_ForumHonored Contributor17 years agoBus pin assignment being ignored by fitter I have a 10-bit wide output bus: out[9..0]. I assigned each output wire to a pin using the pin placement tool. The Live I/O check passes and there are no errors for the pin assignments. However, it s...Show More
Altera_ForumHonored Contributor17 years agoMaybe copy and paste the warnings you mentioned to provide more insite into the problem.
Recent DiscussionsSSLC Login Issue – "You need to enroll" loop after OTP verificationflexlm errorQuesta Sim on Windows - linking to external LIBSolvedFree Licence for Max+PlusIIQuartus crashes on long carry chain in Agilex 5 FPGAs
