--- Quote Start ---
Hi
I ran the aocl diagnostic command. I get DIAGNOSTIC_PASSED Message at the end.
I did follow the instructions specified in the aforementioned link to set up the altera environment.
The CvP failed error has been happening for all the applications that have tried executing, including the altera samples.
The bus error happens only with the multi kernel application. And the error disappears if I introduce intermediate prints between the kernel calls
Yes 13.0Sp1 is the first version that I have ever used.
--- Quote End ---
Have you make progress in this issue? Thanks!
