12 years ago
Bumping on this!! Help error message in Quartus II
Hi guys can someone figure out why Quartus II gives me the following error messages without me assigning anything to the .qsf file:
Error message is below:
Error (125048): Error reading Quartus II Settings File C:/altera_trn/VHDL_uppgift_4e/VHDL_uppgift_4e.qsf, line 41
Info (125063): set_global_assignment -name EDA_TEST_BENCH_MODULE_NAME "VHDL_uppgift_4e_vhd_tst " -section_id "VHDL_uppgift_4e_vhd_tst "
Error (125022): Section identifier missing or not required
Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation"
Info (125063): set_global_assignment -name EDA_NATIVELINK_SIMULATION_TEST_BENCH "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation
Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst -section_id eda_simulation"
Info (125063): set_global_assignment -name EDA_TEST_BENCH_NAME "VHDL_uppgift_4e_vhd_tst " -section_id eda_simulation
Error (125080): Can't open project -- Quartus II Settings File contains one or more errors
Error: Quartus II 64-Bit Hierarchy Elaboration was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 381 megabytes
Error: Processing ended: Thu Dec 12 12:47:21 2013
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:00
Thanks for any help offered:oops:
