9 years agoBuild Megawizard/QSYS Systems from command-line (for build environment)
Hi. I want to build my Quartus projects (huge Arria II GX and Arria V setups) automatically on a remote build server. But there's one major problem: My project contains multiple Megawizard...
9 years agoHello _X_,
the "qsys-generate" command builds your qsys system from a .qsys file:
qsys-generate --synthesis=VERILOG soc.qsys
"qmegawiz" to build your megawizard component:
qmegawiz -silent OPTIONAL_FILES=NONE pll.v
These commands can be used from a console or called from a .tcl script. There is no need to store the .qip file in the repository as this and the .sip files are generated with above commands from your <module>.v (or .vhd). Dirk
