11 years agobuild issue with EDS
hi all, I built hello_world through make -f Makefile command, but it showed"arm-linux-gnueabinf-g++: error : /libpath:C:/altera/14.1/hld/host/windows64/lib/: Invalid argument", "arm-linux-gn...
8 years ago --- Quote Start --- I is beginner in this OpenCL theme and in yesterday has download the last version of HelloWorld, install last version of Quartus Std 17.1 & SDK for OpenCL with ARM DS-5, my board is c5soc, OS Win7 Prof. And I see the same problem with "--arm" key in downloaded Makefile as is recommended from craueralt ! Where are trouble ? My output errors is:
/libpath:D:/intelFPGA/17.1/hld/host/windows64/lib: Invalid argument
OpenCL.lib: No such file or directory The command "aocl linkflags" says: /libpath:D:/intelFPGA/17.1/hld/host/windows64/lib OpenCL.lib In D:/intelFPGA/17.1/hld/host/windows64/lib I see the normal file OpenCL.lib. How repair this bug ? --- Quote End --- hi! I have the same problem,have you solved it? I want to change the output of "aocl link-config",how can I implement this? By the way,do you know the output of "aocl link-config" depends on which variable's value ???ygao15
7 years agoI have the same problem as you,do you solved it? I am looking forward to your help.
