11 years agobuild issue with EDS
hi all, I built hello_world through make -f Makefile command, but it showed"arm-linux-gnueabinf-g++: error : /libpath:C:/altera/14.1/hld/host/windows64/lib/: Invalid argument", "arm-linux-gn...
8 years agoA problem is in "invisible" key "--arm" for command in Makefile after "shell aocl link-config", which must return a list of ARM linker parameters instead x64.
If manually edit Makefile, clear AOCL_LINK_CONFIG, set to LIB_DIRS list of library directories and add to LIBS all need libs, then examples is compiled and runned after successful.
