13 years ago
[Bug report QII 12.0] FSM-Viewer doesn´t show Graph when compare integer&unsigned
Hi, I use the IEEE.numeric_std.all Library for programming in VHDL. When the programcode consits a comparison between unsigned and integer the syntax checker tell that all is ok an the code compiles...
