EGrub
7 years agoBUG in simulation library for dcfifo_mixed_widths with Modelsim
If a dcfifo_mixed_widths is used (because I need the mixed width) but write and read side getting the same clock signal then simulation fails. With the read request signal the output changes immedia...
EGrub
7 years agoHi YY!
Thank you for your reply!
Have you read my previous reply? It seems that in my case Modelsim changed the priority of the input signals and the read request signal was computed before the clock signal! As I wrote above one can see it with event mode enabled.
I have no idea why that happened, I will not further investigate on it.
How to continue?
Erich
