EGrub
7 years agoBUG in simulation library for dcfifo_mixed_widths with Modelsim
If a dcfifo_mixed_widths is used (because I need the mixed width) but write and read side getting the same clock signal then simulation fails. With the read request signal the output changes immedia...
EGrub
7 years agoHi YY!
In advance sorry for the following reply, it is nothing against you personally and I know it would maybe fit better into the flames, but:
Intel decided to replace a good working support tool (the old service requests) by a non working forum at all with the following drawbacks:
- No direct support
- The forum has a lot of bugs it self!!!
- No subcategories
- no possibility to provide confidential data
- the old forum worked better
- and some more
So no I will not provide you with my simulation because you will not be able to run it anyway.
No I will not provide you with a non-confidential design because I will not get time from my boss to generate it.
Please report to your boss that I'm unhappy with the overall support (not your support) but the type of support and the forum it self.
Erich
