EGrub
7 years agoBUG in simulation library for dcfifo_mixed_widths with Modelsim
If a dcfifo_mixed_widths is used (because I need the mixed width) but write and read side getting the same clock signal then simulation fails. With the read request signal the output changes immedia...
KhaiChein_Y_Intel
7 years agoHi EGrub,
Could you provide the design for investigation? Which version of the software you are using?
