EGrub
7 years agoBUG in simulation library for dcfifo_mixed_widths with Modelsim
If a dcfifo_mixed_widths is used (because I need the mixed width) but write and read side getting the same clock signal then simulation fails. With the read request signal the output changes immedia...
AndyN
7 years agoDo you have the intended_device_family parameter set to something other than default? For some reason, the simulation models for the fifos seem to do strange things otherwise...
Hope that helps,
Andy
