9 years agoBuffering a signal.
I'd like to understand. Suppose I do so
signal_1 <= signal_0;
signal_2 <= signal_1;
if signal_0 is '1' on the first clock and '0' on the second - does signal_2 keep its value for two clock...
9 years agoA signal set under clock edge control (= a flip-flop) can be active for one clock period, but not shorter. Activation for one clock cycle can be e.g. achieved by sorting your code like this:
elsif (clk0'event and clk0 = '1') then
signal_0_synch <= '0';
case cond is
when 1 => ------------
when 2 => signal_0_synch <= '1';
end case;
signal_1_synch <= signal_0_synch;
signal_2_synch <= signal_1_synch;
end if; Consider that all registered signals are updated after all assignments scheduled at the respective clock edge have been made. If a signal is only assigned once, the assignment order in the sequential code doesn't matter. But if you have multiple assignments to the same signal in a process, the last assignment wins.
