9 years agoBuffering a signal.
I'd like to understand. Suppose I do so
signal_1 <= signal_0;
signal_2 <= signal_1;
if signal_0 is '1' on the first clock and '0' on the second - does signal_2 keep its value for two clock...
9 years agoI see. Thank you.
One more question. Is it valid to do so?
process(reset_n, clk0)
begin
if reset_n='0' then
signal_1_synch <= '0';
signal_2_synch <= '0';
elsif (clk0'event and clk0 = '1') then
signal_1_synch <= signal_0_synch;
signal_2_synch <= signal_1_synch;
signal_0_synch <= '0';
end if;
end process;
I need to reset signal_0_synch immediately and keep value of signal_2_synch for 2 clocks.
