9 years agoBuffering a signal.
I'd like to understand. Suppose I do so
signal_1 <= signal_0;
signal_2 <= signal_1;
if signal_0 is '1' on the first clock and '0' on the second - does signal_2 keep its value for two clock...
9 years agoHi,
It depends on where do you put those lines. 1. If you put this in clocked process like this process(reset_n, clk0)
begin
if reset_n='0' then
signal_1_synch <= '0';
signal_2_synch <= '0';
elsif (clk0'event and clk0 = '1') then
signal_1_synch <= signal_0_synch;
signal_2_synch <= signal_1_synch;
end if;
end process; signal_2_synch will be 2 clock cyle delayed version of signal_0_synch. 2. If you write outside clocked proces like this signal_1 <= signal_0;
signal_2 <= signal_1; signal_2 would be same as signal_0. Se image attached image: https://www.alteraforum.com/forum/attachment.php?attachmentid=13296 So no it will not keep its value for two clock cycles.
