12 years agoIf user_components.ipx works for both software and HDL, then the IP_IPX_PATH variable should also work.
If you look in the file: $QUARTUS_ROOTDIR\sopc_builder\bin\root_components.ipx At the end of that file, are the lines
<!-- Additional comma-separated list of locations -->
<path path="$IP_IPX_PATH" />
That folder also has the program ip-make-ipx.exe which will create a file called components.ipx for all the components it finds in the directories/subdirectories where you run it. This tool might also work for drivers, I've never tried. You should be able to do something like $ export IP_IPX_PATH=<comma separated paths to .ipx files> $ make (where the makefile calls any of the command-line Altera tools) Cheers, Dave
