broken chip planner
I see Chip Planner regularly working in QPP 22.4 with different designs.
Frank
- PeterL3 years ago
Hi FvM,
Thanks for tests. It turned out something has happened in device migration settings between 22.3pro and 22.4pro.
I use Cyclone 10CX105YF780E5G and migration device 10CX150YF780E5G. Even when I start new design with migration set, chip planner fails. Without migration, it works fine.
BUT there is a caveat, once you set migration and remove it later through menu, quartus still keeps in QSF file
assignement
set_global_assignment -name DEVICE_MIGRATION_LIST 10CX105YF780E5G
which cause chip planner fail. It must be manually deleted from QSF.
As I need device migration, I need to keep this assignment
So, I consider this behaviour a bug in quartus
Peter
