9 years agoBoardTestSystem.exe hang with no response
Hello, We are trying with MAX V development kit. To avoid compatibility between BoardTestSystem.exe and Quartus version, we use the a bit old 10.1 web edition of Quartus. As seen, on our 64bit w...
9 years agoHe is using it because those "board test" applications only work if you have installed the exact same version of Quartus that they used. It makes it a real pain and I don't understand why they didn't do something with systemconsole instead. It would be a lot more universal and flexible.
I think you'd be better off directly trying some sample designs instead of wasting time trying to make the board test application work.
