9 years agoBoardTestSystem.exe hang with no response
Hello, We are trying with MAX V development kit. To avoid compatibility between BoardTestSystem.exe and Quartus version, we use the a bit old 10.1 web edition of Quartus. As seen, on our 64bit w...
9 years agoI don't understand why you are using such an old version of Quartus. You could try installing just a current version of the Quartus Programmer to see if you can connect to the board (http://dl.altera.com/?product=qprogrammer#tabs-4). Also, there may be jumpers or switches on the board that must be set a certain way. Check those.
