8 years agoBluePrint Platform Designer
I heard about the Blueprint Designer tool from Quartus Prime features. I have installed Prime Lite Edition. Please tell me how can i download the Blue Print Platform Designer for pin planners?
Blueprint Designer is available in Intel Quartus Prime Pro & Standard Edition. https://www.youtube.com/watch?v=oz9hcpzsabu https://www.youtube.com/watch?v=rzsix805f_u Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Blueprint is now called Interface Planner. Qsys is now called Platform Designer. There's no such thing as Blueprint Designer.
And Interface Planner is only available in the Pro edition, not the Standard edition. - Altera_Forum
Ok Sir. When we synthesize the project with DDR II, then this option will be enabled in Tools?
Because we have already purchased License Quartus Prime Standard Edition, I have assigned pins in module and synthesize the project, this option is not seeing in Tools. - Altera_Forum
As I said, it's only in the Pro edition.
Thanks sstrel, --- Quote Start --- Ok Sir. When we synthesize the project with DDR II, then this option will be enabled in Tools? Because we have already purchased License Quartus Prime Standard Edition, I have assigned pins in module and synthesize the project, this option is not seeing in Tools. --- Quote End --- Apologize, Blueprint Designer is only supported in pro edition, NOT IN STANDARD EDITION. That means you required license. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
