10 years agoBlue Screen on Windows 10
I use Quartus 15.1 lite for my DE0-CV board. When I programming my board, it blue screen (IRQL not less or equal) all the time. I am pretty sure it's not my hardware issue since a lot of my classmate...
10 years agoThe crash occurs when (eg) you auto-detect the Jtag chain.
This problem is latent and still there in Quartus 16.0. So far, I had this problem on 5 different computers, laptops or desktops. It seems to be a regression in the Blaster driver and could be related with motherboards with an AMD CPU. I found 2 possible solutions : 1. The longest and probably cleanest way : Remove ENTIRELY Quartus (stop the jtag service), remove the whole directory and clean the registry (ccleaner). Then re-install 16.0 from scratch, ending with the installation of the USB driver. 2. The fast easy way : In the device manager remove/uninstall the Blaster driver. Get a copy of the 13.1 drivers directory (\altera\13.1\quartus\drivers\usb-blaster) Install manually this older driver. It worked every time. Hope this helps, Bert
