8 years agoBlock Design Pin Connection Issues
Hello, I'm having a weird one off problem with Quartus Prime 16.1 on a Windows 10 machine. When adding symbols and pins(inputs, outputs, etc...) the nodes appear to connect but dragging either ...
8 years agoHi,
1.Which edition of quartus 16.1 you are using? Use rubberbanding option https://www.usna.edu/ee/ee334/documents/quartus%20common%20issues.pdf or Have you created the .bsf (Non working Environment) and checked? Can try loading the working .bsf to non working environment and check. Or try be using latest version quartus. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
