10 years agoBJT Code needs Debugging
Hi, I'm trying to compile the attached source codes. The NPN & PNP BJTs are in VHDL and the diode code is in verilog. I am using Quartus. Need help debugging. Any help will be ap...
10 years ago --- Quote Start --- The 'electricalsystem' VHDL package is not synthesisable and there are function calls in the verilog without any definition of the function, not to mention the boundless real parameters declared. Quartus won't have any of that. None of these modules are intended for use in an FPGA. Cheers, Alex --- Quote End --- Hi, thanks for the response. Can the attached jpeg vhdl source code for BJTs be used in FPGA? Plus is there a tool that you know of that can input VHDL/verilog source code and output the algorithm implemented in equation form? And a tool to convert VHDL/verilog to python? Thanks.
