12 years agoBittware S5PH-Q 14.0 flash issue
Hi all, I have recently upgrade my Bittware card to Quartus 14.0 which previously had 13.1.3. I was able to successfully install the BSP and flash the board with the Bittware provided top.rbf...
12 years ago --- Quote Start --- Ok thats great. I started with the "Hello World" Example and that worked. Since then I have gotten the Altera 2d-FFT examples to work. What sort of problems are you having? --- Quote End --- Bruce, I get an internal comipler error. When I look at the first error in the quartus_sh_compile.log, it tells me "Current license file does not support partial reconfiguration. The Quartus II software automaticall disabled partial reconfiguration support on all partitions" I spoke with Bittware and they said this is an issue with the quartus.ini file. They gave a known good quartus.ini file to compare with the one located in $AOCL_BOARD_PACKAGE_ROOT/hardware/s5_ref. The files are identical. Any tips? I was able to get hello_world to compile and run for another board vendor.
