12 years agoBittware S5PH-Q 14.0 flash issue
Hi all, I have recently upgrade my Bittware card to Quartus 14.0 which previously had 13.1.3. I was able to successfully install the BSP and flash the board with the Bittware provided top.rbf...
12 years ago --- Quote Start --- Ok that happened to me too, your system is not Posting. Here is what I did: power down the computer, remove the board from the PCI bus, connect a power cable from the motherboard to the FPGA board. . --- Quote End --- After looking for a power cable and failing (modular power supplies are not always the best) I ended up finding an old computer to power the board and erased the flash over usb. When I reloaded top.rbf with "compressed" deselected, aocl diagnose found the board. So I will test the demo tomorrow, but it's a step forward, thanks.
