12 years agoBittware S5PH-Q 14.0 flash issue
Hi all, I have recently upgrade my Bittware card to Quartus 14.0 which previously had 13.1.3. I was able to successfully install the BSP and flash the board with the Bittware provided top.rbf...
12 years ago --- Quote Start --- Your solution about deselecting "compress" during the flash process worked. My linux box booted up. I am still having issues compiling to the board though so I am trying to work through that. I also heard back from Carlos and he mentioned that the getting started guide is wrong. You should not select "compress" when flashing the board. Hopefully that gets updated soon. --- Quote End --- Ok thats great. I started with the "Hello World" Example and that worked. Since then I have gotten the Altera 2d-FFT examples to work. What sort of problems are you having?
