12 years agoBittware S5PH-Q 14.0 flash issue
Hi all, I have recently upgrade my Bittware card to Quartus 14.0 which previously had 13.1.3. I was able to successfully install the BSP and flash the board with the Bittware provided top.rbf...
12 years agoBruce,
Your solution about deselecting "compress" during the flash process worked. My linux box booted up. I am still having issues compiling to the board though so I am trying to work through that. I also heard back from Carlos and he mentioned that the getting started guide is wrong. You should not select "compress" when flashing the board. Hopefully that gets updated soon.
