12 years ago --- Quote Start --- I am kind of confused as to how to enable the output of prbs to be in sink with the incoming received bits to make the comparison to check for bit error. --- Quote End --- if you have real tx/rx system in action then you expect some delay for data to reach rx from tx. Thus the rx must generate a data valid signal to indicate validity of data. You wait for this valid to appear and use as enable for your prbs.
