Altera_ForumHonored Contributor12 years agoBit error tester to test FPGA the PRBS generates bits using 4 bit LFSR. i want to test for the bit error at the receiver using VHDL code. Using FIFO would be a good option to store the bits one by one? And the same LFSR ca...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
