12 years agoi have attached the vhdl code for the reciever. I have generated the same pseudo random sequence as that of the txr, in the rxr also and compared each bit with the received data. If the value is different , count is incremented.
I am constantly getting the following error: 1. No feasible entries for infix operator "xor". 2. Type error resolving infix expression "xor" as type std.standard.boolean. library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; use ieee.std_logic_arith.all; use ieee.std_logic_textio.all; -- entity ber is port ( rxd_bit : in std_logic; clk : in std_logic); end ber; architecture ar of ber is type data is array(0 to 63) of std_logic; signal d: data; signal c,m,t: integer:=0; signal count: integer:=0; signal q:bit_vector(3 downto 0):="0001"; signal k:bit_vector(3 downto 0); begin process(clk) is begin for c in 0 to 63 loop if rising_edge(clk) then d(c)<= rxd_bit; end if; end loop; for i in 0 to 15 loop q<=(q(2)xor q(3)) &q(0)&q(1)&q(2); k<=q; for t in 0 to 3 loop if(k(t) xor d(t)) then ---------------------> error in this line count<= count+1; m<= m+1; end if; end loop; end loop; end process; end ar;
